This content has been marked as final.
Show 3 replies
Re: Static simulation on complicated part
Frederick Law Feb 13, 2019 2:10 PM (in response to Odd Ramone)Its not really complicated.
Someone should be able to help or run the sim for you.
That's a really long arm on small mount.
Shawn Mahaney Feb 14, 2019 7:27 AM (in response to Odd Ramone)The model looks pretty clean. I could probably turn this around in a couple days.
Is there a technical drawing detailing the welds and other hardware?
Odd Ramone Feb 14, 2019 2:18 PM (in response to Odd Ramone)I have not made the welds in the model. Is it best that I insert weld beads in the model? Insert --> Assembly Feature --> Weld Bead?
What I want to find out is how much stress it will be on the structure under different G forces. On the picture you
see where the structure shall be fixed.
I want to know what happens to the structure when adding these G forces:
Y axis (upp and down): 3,75G and 2,2G
X axis: (to the sides): 1,0G
