CKChris Kratz24/03/2009
We have a Add-In module build with Visual Basic .Net 2008, and are using it with SW 2009 64bit on WinXP 64 bit.
Our users keep getting the "The object invoked has disconnected from its clients?. (?Exception from ?HRESULT?: ?0?x?80010108 ?(?RPC_E_DISCONNECTED?))" error.
It is hard to pin down because it does not occur all the time and does not occur in the same spot in the code. It appears to happen randomly.
Is there any way to prevent this from happening?
Is there any way to detect this situation?
Is there any way to recover once this happens in the application?
Below is some example code that sometimes produces the error(not always).
Public Function RenameComp(ByVal OldName As String, ByVal NewName As String, Optional ByVal SWApplication As SldWorks.SldWorks = Nothing) As String
Try
If IsNothing(SWApplication) = True Then SWApplication = SWApp
'select the comp by its old name
swModel = SWApp.IActiveDoc2
If swModel Is Nothing Then
Throw New Exception("Active document is nothing. Cannot select cabinet")
Dim cname(0) As String
cname(0) = OldName
SelectComponents(cname, False, SWApp)
Dim SelMgr As SldWorks.SelectionMgr
SelMgr = swModel.SelectionManager()
Dim SelComp As SldWorks.Component2 = SelMgr.GetSelectedObject6(1, -1)
If SelComp Is Nothing Then
Dim this As New Exception("Could Not Select Cabinet")
Throw this
'Change the name to the new name
SWApp.SetUserPreferenceToggle(SwConst.swUserPreferenceToggle_e.swExtRefUpdateCompNames, False)
SelComp.Name2 = NewName
Return SelComp.Name2
Catch ex As Exception
Throw New Exception("Failed RenameComp. OldName[" & OldName & "] NewName[" & NewName & "]" & ex.Message)
End Try
End Function
