I'm having a problem with weldolet not attaching the pipe properly when in downward position ( -Y axis).
The weldoled works fine in other 3 positions, upward and sideways. Just not in downward position, and i don't have a clue why. As you can see in the first picture, when i give dimension for pipe lenght that problem occurs.
The part is from SW database but edited so it can fit to a 28" pipe, 28" x 2".
I also have a second question regarding the weldolet, pipe penetration and Flow Simulation, is it possible to somehow penetrate the pipe with weldolet so that the flow simulation will take that section into it's calculation?
Thanks!
Dusko,
The first issue you mention is a bug. I've had similiar things happen even without weldolets.
Concerning the second issue with flow simulation : you'll have to ask your VAR about that but I would think that without work-arounds the answer will be "no, you can't" because, as you'll have noticed, putting a weldolet down in Routing doesn't even create a hole in the the main pipe wall.
