Re: How do I determine why a sub-assembly stops moving?
Glenn Schroeder Feb 11, 2019 3:47 PM (in response to Brian Catlin)Expand that component in the tree, expand its Mates folder, and start suppressing them until you get movement back.
Brian Catlin Feb 11, 2019 3:49 PM (in response to Glenn Schroeder)Seriously? Trial and error is the only way?
Andy Sanders Feb 11, 2019 4:06 PM (in response to Brian Catlin)Basically, yes. It's an art you eventually get better at.
Alex Lachance Feb 11, 2019 4:14 PM (in response to Brian Catlin)The program cannot know what kind of movement you are intending it to do... You should know what mates you have and what controls your assembly so it shouldn't be too hard to find which mates stops you from doing your movement.
Edit: Probably that you have 2 parts fixed inside your assembly and are mated along both parts. Maybe the part or assembly you are trying to move is fixed. You can tell if it is fixed if there's a little (f) next to the component name in the feature manager.
Kevin Chandler Feb 11, 2019 4:27 PM (in response to Brian Catlin)Brian Catlin wrote:
Or upload your files for the forumites to peek at?
Or add some screen shots?
Or explain better?
Or rollback things?
Or suppress assemblies?
Brian Catlin Feb 11, 2019 4:34 PM (in response to Kevin Chandler)It is 41MB as a Pack 'n' Go zip file, which is larger than can be attached here. If anyone is interested in looking at it, here is a link to the zip file: https://1drv.ms/u/s!AnHYCbebxUCp5fRGt7008oen3rMIMQ
The sub-assembly that used to move, and no longer does, are the green legs in the back of the robot. They should rotate about the shaft they are attached to
Jim Sculley Feb 11, 2019 4:54 PM (in response to Brian Catlin)It's rotating for me.
Brian Catlin Feb 11, 2019 4:58 PM (in response to Jim Sculley)Jim, what version of Solidworks are you running?
How can I debug this?
Alex Lachance Feb 11, 2019 5:01 PM (in response to Brian Catlin)Brian,
See if you deactivated the setting that allows you to do so. It should be in Options>Assemblies> Move components by dragging (checkbox)
Brian Catlin Feb 11, 2019 5:07 PM (in response to Alex Lachance)It is set. I can drag the pink arm, but the legs no longer move for me.
Since someone else was able to get the legs to move, it appears to be a bug in the Education 2018-2019 version of Solidworks :-(
Kevin Chandler Feb 11, 2019 5:11 PM (in response to Brian Catlin)Brian Catlin wrote:
I have SW18-19 at home.
If I get the time, I'll see if this is an accurate statement.
Kevin
Brian Catlin Feb 11, 2019 5:13 PM (in response to Kevin Chandler)Thank you, Kevin!
Kevin Pymm Feb 12, 2019 4:06 AM (in response to Brian Catlin)Brian,
I am using SW2019 SP1 & just to confirm, I have opened your assembly & I am able to rotate the green arms OK.
Kevin Chandler Feb 12, 2019 8:06 AM (in response to Brian Catlin)Brian Catlin wrote:
Another item, resist the urge to blame the software, as most of the time, it's you who is at fault.
Better to develop the mindset that you are the one who created the issue and you are the one who will remedy the issue.
"A poor carpenter blames his tools."
Kevin
Brian Catlin Feb 12, 2019 1:19 PM (in response to Kevin Chandler)If the model works in another version of Solidworks, then clearly the model is not the problem! That leaves the configuration and the differences in versions of the software. The configuration values that control movement appear to be the same, therefore, the software must be the problem.
Josh Brady Feb 12, 2019 1:48 PM (in response to Brian Catlin)Brian Catlin wrote:
So... In your car you have a gear shift lever. You have a gas pedal, brake pedal, lots of controls. You can do lots of different things with your car, and for the most part the car will let you. But there are certain things that'll give you better results. If you choose to drop it into low and then drive 200 miles to Atlanta on the interstate at 70mph, (as my wife recently did) it will let you do that. But you won't be happy with its behavior (she wasn't either...). One vehicle might make it there in one piece, another vehicle might drop the transmission in the middle of I-75. I'm not sure the vehicle is entirely to blame in either case...
Regarding setting things as flexible, they only have to be flexible if you want the subassembly components to move relative to one another in the higher level assembly. If you group your subassemblies such that things that move as a unit make up the subassembly, then all you have to do is mate it in the main assembly.
Brian Catlin Feb 12, 2019 2:02 PM (in response to Josh Brady)I'm not sure that the analogy is relevant, because the behavior of the model varies depending upon the version of Solidworks that is being used, but I thank you for your advice and your time.
I'm trying to understand your meaning regarding using Flexible. Do you mean that I shouldn't have modeled the 4-bar linkage of the arm as a single assembly? How else should I have modeled it? It seems to me that it would always have to be set Flexible for it to move in the main assembly
Josh Brady Feb 12, 2019 4:44 PM (in response to Brian Catlin)Brian Catlin wrote:
It's more of a performance thing than a bug... Your current version of SW has just sorta ground to a halt trying to process it (the tranny fell out). SW knows that it should still be able to move because there's a minus( - ) showing, it's just not able to do all the calculations it needs to in order to move it live relative to an attempted linear drag. Mates in SW are analagous to a giant system of equations. Every mate adds more variables and equations that have to solve simultaneously. Rigid subassemblies break that system up into chunks. SW can solve the mates of the subassembly, then ignore those mates from then on. When you make a subassembly flexible, SW has to include all of that subassembly's mates into the top level mate solving, and it has to push things back and forth between main assembly and subassembly etc., you lose all performance benefit of subassemblies. Making flexible subassemblies drive the position of other flexible subassemblies is a nightmare computationally.
Regarding the 4-bar linkage, I would have grouped things sorta like this:
All of the items I highligted in green always move together as rigid body. There is no relative motion between them. So they make a great subassembly. I would make:
-That upper thing a subassembly (Probably go ahead and include the bearings on the left side that I missed selecting)
-The lower one that's just like it a subassembly, (Actually, I'd probably just cut the corner off both of 'em so that they're 2 copies of the same subassembly)
-The two short end linkages are just independent parts at top level
-The two vertical support stand/arms a subassembly.
Each of those subassemblies makes up a rigid body. Then you can add mates appropriately to the subassemblies at the top level to allow motion. You'll end up with a few more components in your feature tree at the top level, but the overall performance will be MUCH better if each subassembly is rigid.
If you really want to make that whole pink thing a subassembly that would not be too bad. You would still only be driving changes one level deep, and for performance you could turn flexible on and off as needed for that one subassembly.
Brian Catlin Feb 12, 2019 4:59 PM (in response to Josh Brady)Ah! I see. That makes sense. Thank you for the lesson
Josh Brady Feb 12, 2019 10:52 AM (in response to Brian Catlin)Brian Catlin wrote:
Your model and mating scheme has a lot of complexity. Any time you have a subassembly, but you have to set it flexible, it's best to step back and ask yourself why, and if you can avoid it. You have multiple levels of flexible subassemblies inside other flexible subassemblies. When you use flexible subassemblies, you get almost none of the benefits of a subassembly, at least with regard to top level performance. It's actually worse than just having everything in the top level. Technically, if you carefully manage the mates, it should work. However, SW doesn't like to position multiple flexible subassemblies that all depend on one another. Your fixed orange stand has mates that depend on the position of the green frame. Since the orange stand doesn't move, it's a waste of resources to make SW figure out that when the green frame moves the orange stand should not move. Mate the orange stand to something fixed. Bring your fixed mounting brackets out of the green subassembly and mate them to the base. Then mate the orange stand to those instead of mating to the green frame subassembly.
Design-wise, I would recommend not mounting your fixed orange frame to the rotating hex shaft anyway. You have nothing rigid to keep the arms of the orange frame from sliding back and forth on the hex shaft. The bearings appear unretained, and they may pop out of the (I assume) press fit holes as they waller out. In general, never use a moving joint when a fixed one will do.
Brian Catlin Feb 12, 2019 1:29 PM (in response to Josh Brady)Yes, it grew by accretion with several kids working on it. Overall, I'd say they did a pretty good job, but I take your point. I'm certainly not an expert at Solidworks, either.
The orange arm was designed to lean forward. It isn't currently, but that capability may be resurrected once the robot is built and testing starts. That's why it is still hinged on the hex shaft. I was about to add the retaining clips to the hex shaft, but after I added the green leg assembly is when I ran into the movement problems, and hadn't gotten to it yet.
It was my understanding that sub-assemblies always had to be marked Flexible if they were to move. That is not the case? Is there a Best Practices guide for Solidworks?
Thank your for your analysis and the time you spent on this. It is much appreciated!
Alex Lachance Feb 12, 2019 1:58 PM (in response to Josh Brady)To add on to what Josh said about flexible sub-assemblies, they are not all that reliable.
One thing that can prevent you for instance of moving a component in a flexible sub-assembly that you were previously able to move could be something as feeble as the fact that you shut SolidWorks down and restarted it. For some reason when you restart SolidWorks it generally forgets that sub-assemblies are flexible, probably to alleviate the loading time.
As Josh Brady pointed out, flexible sub-assemblies tend to cause more problems then they can help with so you are better off asking yourself if your assembly really requires to be flexible. It is a good thing to note that you can have ''flexible sub-assemblies'' that are entirely mated.
We have a similar case to yours, our landing gears. What we like to use here is the following, 3 configurations; Max height, minimum height and a flexible configuration that slides between maximum and minimum height. Having a limit distance mate can help on the flexibility of sub-assemblies.
Cheers.
Edit: Our landing gear is further down a few levels of our sub-assemblies. If we need to do a study to know how far the legs can stretch we will not set all the sub-assembly levels to flexible as that is way too intensive. Instead we will reinsert the landing gear in the assembly where we require the study just for the current need and after that either supress or entirely delete it from there.
Brian Catlin Feb 12, 2019 2:14 PM (in response to Alex Lachance)As far as I know, all I did was shutdown Solidworks for the day and the next day it didn't work again. That seems to be very odd behavior! Is there a way to get back to the previous state? I did notice that when I restarted, the leg assembly was not marked Flexible and that area of the property page was grayed out. I pressed the Rebuild button and then it was back to being marked Flexible, but it didn't move.
I don't think that we have time to restructure the model (this is for a robotics competition, and time is running out), even if we knew how the assemblies should have been designed. Is there a Design Guide or Best Practices Guide that you would recommend? I've taught several of the kids to the point where they've gotten their CSWA, but clearly I need to know a lot more.
Thank you for your time. It is much appreciated!
Alex Lachance Feb 12, 2019 2:18 PM (in response to Brian Catlin)Set your flexible sub-assemblies back to rigid and then set them back to flexible, everything should get back to how it worked the previous day imo unless something did change in between both days in the sub-assemblies.
I don't really have any book to advise you, perhaps you can look into the Skeleton Sketch Method. It is a very interesting method of working once you understand how it works.
Matt Penneguy did a nice thread about it if you ever wonder
Glenn Schroeder Feb 12, 2019 3:29 AM (in response to Brian Catlin)Yes, trial and error is the only way. As Alex Lachance said, the software can't read your mind to know what movement you want to allow. If it's constrained it's almost certain that it got that way because of something you did.
Sergio Monti Feb 12, 2019 4:48 AM (in response to Brian Catlin)Have you tried to drag using right-mouse-button?
Brian Catlin Feb 12, 2019 1:36 PM (in response to Sergio Monti)Oddly, that worked. Sort of. It moves, but not in a predictable way; its movement seems random. When I use the right mouse button on the orange arm, both it and the green legs move together. I suspect it has to do with the mates that others have pointed out.
Why is it that I can move the large orange arm with the left mouse button, but not the green legs? How does left mouse button differ from right mouse button when dragging assemblies?
