Please see the attached SW2018 Part. I don't do this kind of thing very often, and wondered if anyone has a simpler method of accomplishing the same result (the transition between the two bodies). It needs to consist of all flat surfaces, so as far as I can figure out a Loft between the profiles won't work since that creates twisted surfaces.
Glenn,
Can you add a Screen Shot so I have an idea of what you are tackling... Thanks.
Daen
