5 Replies Latest reply on Feb 9, 2019 2:32 AM by Deepak Gupta
    Check sheet scale for each view
    Mehmet Gultepe
      I tried to make a macro that checks each view on the Sheet Scale or not to eliminate the human error when you are save it as dxf. I know when you save it to dxf it warns you but we still miss that sometimes.
        • Re: Check sheet scale for each view
          Deepak Gupta
          Are you looking for a macro to set scale of each view to sheet scale? This can create issue for views which are created with different scale value like detail views.
              Mehmet Gultepe
              no because of the reason you mentioned. We dont use detail view on that sheet but sometimes we use views off the sheet scale. That’s why I want a macro that checks each view equals to sheet scale or not and show that in a mesage box. Like “all views are sheet scaled” or “view 4 is not sheet scaled” or “2 items are not sheet scaled” if there is only one item off the sheet scale you would know and ignore the message.
              we use this specific sheet for tooling or cnc programing. When we do the dxf and if we dont notice that it’s not sheet scaled we end up having wrong size tooling or cutting wrong size material. That’s why I want designers and document checkers have less human error and they dont have to go thru each view, save them time with this macro.
                Mehmet Gultepe
                So I found swView.UseSheetScale. That helped a lot to figure this out. I also find out that if you use swView.UseSheetScale = True for changing it to sheet scale, it doesn't change detail view scale. This macro worked perfectly. Some views are on the user defined scale but when you change sheet scale it doesn't update those views so this macro detect those views too.
                Dim swApp                       As SldWorks.SldWorks
                Dim swModel                     As SldWorks.ModelDoc2
                Dim swSelMgr                    As SldWorks.SelectionMgr
                Dim swView                      As SldWorks.View
                Dim boolstatus                  As Boolean
                Dim currentSheet                As Sheet
                Dim swDraw                      As SldWorks.DrawingDoc
                Dim X                           As Integer
                Dim Y                           As Integer
                Dim swScale                     As Double
                Dim bRet                        As Boolean
                Dim vSheetProps                 As Variant
                    X = 0
                    Y = -1
                    Set swModel = swApp.ActiveDoc
                    Set currentSheet = swModel.GetCurrentSheet
                    Set swView = swModel.GetFirstView
                        Do While Not swView Is Nothing
                              If Not swView.UseSheetScale = False Then
                              Else
                                X = X + 1
                        Y = Y + 1
                        Set swView = swView.GetNextView
                        Loop
                    If X = 0 Then
                        MsgBox "All views are sheet scaled"
                    Else
                        MsgBox ("number of the views are not sheet scaled: " & X)
                    'MsgBox ("number of the view Y:" & Y)
                    swModel.ForceRebuild3 False
                Gennadiy Tsybikov
                Here's another macro I made to figure out if views are not on Sheet Scale.
                Option Explicit
                Dim strMessage As String
                Dim dblSheetScale As Double
                Dim dblScale As Double
                    strMessage = "The following views are not on Sheet Scale: " & vbNewLine
                    Set swDraw = swModel
                    If Not swDraw Is Nothing Then
                        SheetScale
                    MsgBox strMessage
                Function SheetScale()
                    Dim vViews As Variant
                    Dim i As Integer
                    Dim boolSheetScaleCheck As Boolean
                    vViews = swDraw.GetViews
                    vViews = vViews(0)
                    ' Get Sheet Scale
                    dblSheetScale = vViews(0).ScaleDecimal
                        For i = 0 To UBound(vViews)
                            Set swView = vViews(i)
                            boolSheetScaleCheck = swView.UseSheetScale
                            dblScale = swView.ScaleDecimal
                            ' Check if view is not on Sheet Scale and its Scale not equals to Sheet Scale
                            If boolSheetScaleCheck = False And dblSheetScale <> dblScale Then
                                strMessage = strMessage & vbTab & swView.GetName2 & "." & vbNewLine
                        Next i
                End Function
                  Deepak Gupta
                  Attached are two macro that would check all views on active sheet or all sheets and report the views that are not set to use parent scale or sheet scale. The macro would skip the section views and detail views. The macro would create a txt file named "View Scale Info" on the desktop and would add the name of the views which are not set to use sheet scale or parent view scale. The macro would also list the view scale along with their names.
