Convert Task Custom Functions
Question asked by Dmitry Zamoshnikov on Feb 6, 2019
So I've been banging my head against the wall trying to figure out why my convert task wouldn't run with the functions I created.
I tested some functions w/in Excel (quick way to test an algorithm, and since it's written in VBA, it should transfer over).
I transferred the functions over, and the task kept failing.
I put "stop" within the convert function, and again, the task failed--didn't bring up the debugger.
I commented out all of my custom function calls and placed "stop" within the code again.  The debugger was brought up.
I uncommented my custom function calls and I get a message "ByRef expected"---huh?  Why would the task expect my strings to be ByRef when I defined them as string.
in excel I have
'   GetNumPos
'       Return first instance of a number
Function GetNumPos(src As String) As Integer
    For GetNumPos = 1 To Len(src)
        If Mid(src, GetNumPos, 1) Like "#" Then Exit Function
    Next
    GetNumPos = 0   ' no number found
End Function
I removed the "as string" and the "as integer" and the function ran fine.
'   GetNumPos
Function GetNumPos(src)
    Next
End Function
So if you're writing custom code w/in the script of Convert Task, remove the "as [data type]" in the function definitions, and see if the task executes.
