Select general table when table is moved (x and y don't match)
Question asked by Frank Van Eygen on Feb 6, 2019
Latest reply on Mar 18, 2019 by Frank Van Eygen
I have a macro to make a general table and fill in some cells.
When I stop the macro, move the general table's position and restart the macro, the macro needs to pick up that general table (name of general table is WeldNumbers) to be able te add rows and continue.
When I do not move the table then the macro can find that same table because the x and y values are the same as when first inserted
value = instance.SelectByID2(Name, Type, X, Y, Z, Append, Mark, Callout, SelectOption)
My problem is that when I move the table, then I can not set swTable to the selected swSubFeat
How can I set swTable by selecting the "WeldNumbers" table?
    If swTable Is Nothing Then
        Do Until swFeature Is Nothing
            'Debug.Print swFeature.Name, swFeature.GetTypeName
            Set swSubFeat = swFeature.GetFirstSubFeature
            Do Until swSubFeat Is Nothing
                'Debug.Print swSubFeat.Name, swSubFeat.GetTypeName
                If swSubFeat.Name = "WeldNumbers" And swSubFeat.GetTypeName = "GeneralTableFeature" Then
                    booEnableEvents = False
                    booWeldTableExcists = True
                    swModel.ClearSelection2 True
                    swSubFeat.Select (False)
                    'Set swTable = swSubFeat '<-- this does not work
                    boolstatus = swModel.Extension.SelectByID2("WeldNumbers", swSelGENERALTABLEFEAT, _
                            0.01, 0.275, 0, False, 0, Nothing, swSelectOptionDefault) '<-- this needs x and y coordinates but if moved then x and y are changes
                    Set swTable = swModel.SelectionManager.GetSelectedObject5(1)
                    booEnableEvents = True
                    AantalRijenTabel = swTable.RowCount
                    UserForm1.txtWledNr.value = swTable.RowCount
                    UserForm1.SpinButton1.value = UserForm1.txtWledNr.value
                    Exit Do
                Set swSubFeat = swSubFeat.GetNextSubFeature
            Loop
            If booWeldTableExcists = True Then Exit Do
            Set swFeature = swFeature.GetNextFeature
        Loop
Thx for any help,
Frank
