I'm trying to use tab and slot between planar ribs and a curved sheet, see below. Whenever I try to pick the curved edge of the rib, I get "Invalid selection, please select a tab edge which is shared by a planar or cylindrical edge". The curved edge is cylindrical (sketched with an arc), so I should be able to use that edge, right? (One of the cool enhancement in 2019 was tab and slot on curved surfaces)
Anyone have any help with this?
SW 2019, SP0
I cannot get that to work too. I downloaded your part and get the same message as you. Somehow, the edge and slot-face are not shared in your part. I cannot see where it goes wrong even if when you resketch the "endplate" with "convert entities" SW still gives the same message.
I did draw a new part with same features as yours, than I am able to select the edge, however than I cannot select the tab-face. So even than I cannot get it to work. I am wondering if it is possible to use tab and slot in this way.
You can use tab and slot other way arround, see attached your modified part, maybe that works for you.
