I've attached the two geometries. I would like to know the ways to create/attach the wire mesh on the roofing sheet.
Duct tape?
Hello Shivam,.. Wrap,.. so, if you have the flat/wire/mesh sketch you can use that sketch to create a Scribe on your corrugated surface.. offset that face and thicken.
(note:.. this geometry is memory intensive)
Would there be any sort of conneticon between the sheet and the mesh after offsetting?
Duct tape?
