What is the correct way to rename a plane that was just created in a macro
Question asked by Jason Martin on Feb 1, 2019
Latest reply on Feb 1, 2019 by Attilio Colangelo
What is the best way to rename each plane that was created from running this macro. It just creates a newly numbered plane1, plane2, plane 3 when the macro is run.
I've tried using:
boolstatus = Part.SelectedFeatureProperties(0, 0, 0, 0, 0, 0, 0, 1, 0, "This is the new plane name")
between each newly created plane, but that doesnt work. Could I get some help with this?
Thanks in advance!
Here is my code:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
' * The distance needs to be set in meters *
Set Part = swApp.ActiveDoc
Dim myRefPlane As Object
boolstatus = Part.Extension.SelectByID2("FRONT", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
Set myRefPlane = Part.FeatureManager.InsertRefPlane(8, 0.127, 0, 0, 0, 0)
boolstatus = Part.Extension.SelectByID2("TOP", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
Set myRefPlane = Part.FeatureManager.InsertRefPlane(8, 0.1524, 0, 0, 0, 0)
boolstatus = Part.Extension.SelectByID2("RIGHT", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
Set myRefPlane = Part.FeatureManager.InsertRefPlane(8, 0.1778, 0, 0, 0, 0)
