Is it possible to insert a part inside an assembly and select only the things you wish to import from the part?
Here's what I'd like to do. I have a multi-body weldment which I'd wish to import only the sketches and perhaps planes to use as references. Is it possible?
Would a display state hiding all the bodies, and then excluding that part do pretty much the same trick...?
