I am creating a Solidworks sketch with rectangles and imported sketches (Eg. font styles from illustrator). The imported sketches were retrieved from illustrator in .dxf format. The .dxf sketches look neat in Solidworks when imported, but when I create drawing and save it as pdf, the resolution is reducing. Eg. the corners were rounded instead of sharp corner, blurred sketch, etc. I tried by increasing the quality of lines to 600 and selecting high quality shaded edges while saving a pdf, but still no luck.
Even on the .dxf export, I am facing similar issue.
Any suggestion is highly appreciated.
Regards,
Natraj
Natraj
If the "Convert draft . . . " option (circled) is not grayed out, then select it.
Dwight
