How to constrain three hollow shafts to make two shafts rotate independent to one another?
Question asked by Sreenath Perumal Ganeshbabu on Jan 31, 2019
Good morning Professionals,
I have three shafts in here and the outer most one is fixed. Middle shaft must rotate inside the outermost one provided the smallest shaft should also rotate along with the middle one. Which is happening perfectly. Now, i need to rotate the smallest shaft independent to the other two shafts. But when i rotate the smallest one it is rotating along with middle shaft as well which is not desired for our simulation. What should i do?
Responses appreciated and it would help us move on with our production.
Thanks and Regards
Mechanical Engineer
