KKKenny Kobetsky30/01/2019
The purpose of this macro is to be able to select multiple surfaces from an assembly, and print out (to excel) the Area and Area Moment of Inertia (Ixx,Iyy,Izz) for each individual surface selected. For example, selecting both surfaces below with cursor, running the macro, and printing to excel each surface's respective Area, Ixx, Iyy, and Izz:
The code below works for one surface, but when multiple surfaces are selected, the macro is unable to distinguish between each individual surface, combines them, and outputs as if one selection was made. Any thoughts?
'Pre-conditions:
'Select surfaces before running macro
'Selection must be a surface
Dim xlApp As Excel.Application
Dim xlBook As Excel.Workbook
Dim xlSheet As Excel.Worksheet
Dim FirstRow As Long
Dim FirstCol As Long
Dim Area As Long
Dim XVal As Long
Dim YVal As Long
Dim ZVal As Long
Dim AMOIxx As Long
Dim AMOIyy As Long
Dim AMOIzz As Long
Dim vComps As Variant
Dim i As Integer
Dim Message1 As String
Dim Message2 As String
Dim swModelExt As SldWorks.ModelDocExtension
Dim swFeat() As SldWorks.Feature
Dim swFaceEnt() As SldWorks.Entity
Dim swSketch As SldWorks.Sketch
Dim nSelType As Long
Dim swSelObj() As Object
Dim vSelObj As Variant
Dim vSectionProp As Variant
Dim nSelCount As Integer
Dim nNumObj As Long
Dim nFeatureArr() As Variant
Set swModel = swApp.ActiveDoc
Set swModelExt = swModel.Extension
'CONFIRM AN ASSEMBLY DOC IS OPEN
If swModel Is Nothing Then
swApp.SendMsgToUser2 "An Assembly document must be open as the active document(Error Code:1).", swMbWarning, swMbOk
Exit Sub
ElseIf swModel.GetType <> swDocASSEMBLY Then
swApp.SendMsgToUser2 "An Assembly document must be open as the active document(Error Code:2).", swMbWarning, swMbOk
Exit Sub
Else
Message1 = "Assembly file confirmed!"
swApp.SendMsgToUser2 Message1, 2, 2 'first 2 = "ok option", second 2 = display info icon
'CONFIRM AT LEAST ONE SELECTION IS MADE
nSelCount = swSelMgr.GetSelectedObjectCount
Debug.Print "Selected Count: " & nSelCount
If nSelCount = 0 Then
swApp.SendMsgToUser2 "You must make a selection before running the macro (Error Code:2).", swMbWarning, swMbOk
Exit Sub
Else
Message2 = "Number of Selections: " & nSelCount
swApp.SendMsgToUser2 Message2, 2, 2 'first 2 = "ok option", second 2 = display info icon
'EXCEL PAGE SETUP
Set xlApp = CreateObject("Excel.Application")
xlApp.Visible = True 'Display the created workbook
Set xlBook = xlApp.Workbooks.Add 'Create a new workbook
Set xlSheet = xlBook.Worksheets("Sheet1") 'Define which worksheet to use within the workbook
FirstRow = 1
FirstCol = 1
Area = FirstCol + 1
AMOIxx = FirstCol + 2
AMOIyy = FirstCol + 3
AMOIzz = FirstCol + 4
FilePath = swModel.GetPathName 'Defining file Path (to use to print to excel)
Debug.Print "FilePath: " & FilePath
FileName = swModel.GetTitle 'Defining file Name (to use to print to excel)
Debug.Print "FileName: " & FileName
'Labels for excel print out
xlSheet.Cells(FirstRow + 1, FirstCol).value = FileName
xlSheet.Cells(FirstRow + 2, FirstCol).value = "Config #"
xlSheet.Cells(FirstRow + 1, Area).value = "Area"
xlSheet.Cells(FirstRow + 2, Area).value = "mm^2"
xlSheet.Cells(FirstRow + 1, AMOIxx).value = "AMOI xx"
xlSheet.Cells(FirstRow + 2, AMOIxx).value = "mm^4"
xlSheet.Cells(FirstRow + 1, AMOIyy).value = "AMOI yy"
xlSheet.Cells(FirstRow + 2, AMOIyy).value = "mm^4"
xlSheet.Cells(FirstRow + 1, AMOIzz).value = "AMOI zz"
xlSheet.Cells(FirstRow + 2, AMOIzz).value = "mm^4"
FirstRow = FirstRow + 3 'start data on row 4
'ACCESSING/READING SOLIDWORKS SURFACE
Dim swFace() As SldWorks.Face2
ReDim Preserve swFace(nSelCount - 1) 're-dimension array to have as many cells as there are selections
For i = 1 To nSelCount
Debug.Print "i: " & i
Set swFace(i - 1) = swSelMgr.GetSelectedObject5(i)
nSelType = swSelMgr.GetSelectedObjectType2(i)
Debug.Print "Selection Type: " & nSelType
nNumObj = nNumObj + 1
Debug.Print "nNumObj: " & nNumObj
ReDim Preserve swSelObj(nNumObj - 1)
ReDim Preserve swFaceEnt(nNumObj - 1)
Set swComponent = swFace(i - 1).GetComponent 'used to get the component name for excel printout
Set swFaceEnt(nNumObj - 1) = swFace(i - 1)
Set swSelObj(nNumObj - 1) = swFace(i - 1)
'Deselect faces and sketches; otherwise, user-interface selections are added to array parameter; leave section faces selected
If Not IsEmpty(swFaceEnt) Then
Debug.Print "Are we here?"
For k = 0 To UBound(swFaceEnt)
swFaceEnt(k).DeSelect
Next k
If Not IsEmpty(swFeat) Then
Debug.Print "Are we also here?"
For k = 0 To UBound(swFeat)
swFeat(k).DeSelect
Next k
'This adds the array of faces or sketches to the selection set because the faces or sketches have been deselected, this preserves the selection set
vSelObj = swSelObj
vSectionProp = swModelExt.GetSectionProperties((vSelObj))
' Return code from: IModelDocExtension::GetSectionProperties
' 0 = success
' 1 = invalid input
' 2 = selected faces are not in the same or parallel planes
' 3 = unable to compute section properties
Debug.Print " Return code: " & vSectionProp(0)
'Print values in excel for each selection
xlSheet.Cells(FirstRow, FirstCol).value = swComponent.GetSelectByIDString
xlSheet.Cells(FirstRow, Area).value = vSectionProp(1) * 1000000#
xlSheet.Cells(FirstRow, AMOIxx).value = vSectionProp(5) * 1000000000000#
xlSheet.Cells(FirstRow, AMOIyy).value = vSectionProp(6) * 1000000000000#
xlSheet.Cells(FirstRow, AMOIzz).value = vSectionProp(7) * 1000000000000#
FirstRow = FirstRow + 1
Debug.Print "Next Empty Row: " & FirstRow
Debug.Print "Area: " & vSectionProp(1) * 1000000#
xlSheet.UsedRange.EntireColumn.AutoFit 'Resize cells to fit all info
Next i
xlSheet.Cells(1, FirstCol).value = FilePath 'print pathname (without resizing cell)
