WaterMark Macro not correct Font Point size?
Question asked by Craig Makarowski on Jan 29, 2019
Latest reply on Jan 30, 2019 by Deepak Gupta
WellI recorded a macro to make a Water mark on my Drawings for Preliminary Drawings. THe Font does not set to the correct size (Should be 72 points), also doesn't seem to have the Behind sheet check mark set as well. here is my Macro
' C:\Users\cramak\AppData\Local\Temp\swx12964\Macro1.swb - macro recorded on 01/29/19 by cramak
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Sheet1", "SHEET", 0.189459370676497, 0.254029203869184, 0, False, 0, Nothing, 0)
Part.EditTemplate
Part.EditSketch
Part.ClearSelection2 True
Part.FontPoints 72
Part.FONTBOLD True
Dim myNote As Object
Dim myAnnotation As Object
Dim myTextFormat As Object
Set myNote = Part.InsertNote("<FONT color=0x00c0c0c0><FONT size=72PTS style=B>PRELIMINARY DRAWING")
If Not myNote Is Nothing Then
myNote.LockPosition = False
myNote.Angle = 0.3490658503989
boolstatus = myNote.SetBalloon(0, 0)
Set myAnnotation = myNote.GetAnnotation()
If Not myAnnotation Is Nothing Then
longstatus = myAnnotation.SetLeader3(swLeaderStyle_e.swNO_LEADER, 0, True, False, False, False)
boolstatus = myAnnotation.SetPosition(0.170992792024719, 0.144460837201969, 0)
Set myTextFormat = Part.GetUserPreferenceTextFormat(0)
myTextFormat.Italic = False
myTextFormat.Underline = False
myTextFormat.Strikeout = False
myTextFormat.Bold = True
myTextFormat.Escapement = 0.3490658503989
myTextFormat.LineSpacing = 0.001
myTextFormat.CharHeightInPts = True
myTextFormat.TypeFaceName = "Century Gothic"
myTextFormat.WidthFactor = 1
myTextFormat.ObliqueAngle = 0
myTextFormat.LineLength = 0
myTextFormat.Vertical = False
myTextFormat.BackWards = False
myTextFormat.UpsideDown = False
myTextFormat.CharSpacingFactor = 1
boolstatus = myAnnotation.SetTextFormat(0, False, myTextFormat)
Part.WindowRedraw
Part.EditSheet
Part.EditSketch
here is the settings even when i set the Behind Sheet check box the recorded macro doesn't seem to capture it!
Result, Font should be very big!
