SW 2017 SP5.0
- Take a top-level assembly
- Create a sketch at the assembly level.
- Select Assembly Features->Extruded Cut
- Select the sketch created above
- Select propagate features to parts
- Uncheck auto-select
- Select the parts you want to propagate the cut to
- Click on the check mark - cut shows up in assembly and parts
- Select Assembly Features -> Linear Pattern
- Select Assembly-level extruded cut
- Set linear pattern properties
- Note that preview shows pattern of sketch on the sketch plane for the assembly-level extruded cut, but only shows parts being cut in the seed position
- Notice how the cut is not patterned.
- Go back and do not propagate feature to part
- Notice how the cut is now pattered in the assembly, but not in the part.
- Wonder why this can't be done.
- Find other bugs in all other work arounds tried.
- Wonder why SW 2017 has more bugs than SW 2008. Did they lose or decline to license a key piece of the software that they thought that they could duplicate themselves but couldn't?
Thoughts?
I don't have SW 2017 so I don't know if it's a bug in that version.
In 2018 it works as it should:
