The code below worked great in Solidworks 2016 (I could adjust the Grid-line and Borderline Weight). In 2019 it still inserts the table I need but inserts the Borderline Weight thick and shows no Grid-lines.
Can someone help me out? I need to be able to chance the Grid-line and Borderline Weights when inserted. Thanks in advance for any help you might be able to give.
Option Explicit
Dim swDrawing As SldWorks.DrawingDoc
Dim swTable As SldWorks.TableAnnotation
Dim GetUserName As String
Const sTablePath As String = "D:\SolidWorks\Tables\GT.sldtbt"
Set swModel = swApp.ActiveDoc
GetUserName = Environ$("username")
If (swModel Is Nothing) Or (swModel.GetType <> swDocDRAWING) Then
swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")
Exit Sub
Set swDrawing = swModel
' Insert general table
Set swTable = swDrawing.InsertTableAnnotation2(False, 1.17982409743605E-02, 1.71811613648901E-02, swBOMConfigurationAnchor_TopLeft, "C:\Users\" & GetUserName & "General Table Location", 3, 1)
If Not swTable Is Nothing Then
swTable.BorderLineWeight = 0
swTable.GridLineWeight = 0
