Save as step with renamed parts
Question asked by Pacquelet Yoan on Jan 28, 2019
Latest reply on Jan 29, 2019 by Deepak Gupta
Hi !
I want to save an assembly in step format with new names for parts and sub assemblies .
I wrote a macro :
it creates a new assembly with description+revision and then rename temporarily all parts and sub assemblies with description+revision.
it saves it in step format and close everything. It works but some parts in the original assembly are renamed why ?
(left: original assemblie, right: step file)
Does anyone can tell me what i am doing wrong ?
Option Explicit
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim swCompConfig As SldWorks.Configuration
Dim swCustProp As SldWorks.CustomPropertyManager
Dim swChildModel As SldWorks.ModelDoc2
'Dim sPadStr As String
Dim i As Long
Dim Reference As String
Dim Revision As String
Dim Description As String
Dim Ver As String
Dim ValOut As String
Dim wasResolved As Boolean
Dim NewName As String
Dim PathName As String
Dim errorsRename As Long
Dim swSelData As SldWorks.SelectData
vChildComp = swComp.GetChildren
For i = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(i)
TraverseComponent swChildComp, nLevel + 1
'Debug.Print sPadStr & swChildComp.Name2 & " <" & swChildComp.ReferencedConfiguration & ">"
Set swChildModel = swChildComp.GetModelDoc
PathName = swChildModel.GetPathName
If _
InStrRev(PathName, "ElementsArchives") <> 0 _
Or _
InStrRev(PathName, "ElementsStandards") <> 0 _
Or _
InStrRev(PathName, "Modèles SolidWorks") <> 0 _
Or _
InStrRev(PathName, "template") <> 0 _
Or _
InStrRev(PathName, "3D COMPOSER") <> 0 _
Then
Debug.Print "composant bibliotheque"
Else
Set swSelMgr = swChildModel.SelectionManager
Set swSelData = swSelMgr.CreateSelectData
Set swCustProp = swChildModel.Extension.CustomPropertyManager("")
swCustProp.Get5 "REFERENCE", False, ValOut, Reference, wasResolved
swCustProp.Get5 "INDICE", False, ValOut, Revision, wasResolved
swCustProp.Get5 "DESCRIPTION", False, ValOut, Description, wasResolved
swCustProp.Get5 "VERSION", False, ValOut, Ver, wasResolved
If Ver = "" Then
NewName = Reference + " " + Revision + "_" + Description
Else
NewName = Reference + " " + Revision + "_" + Ver + "_" + Description
swChildComp.Select4 False, swSelData, False
swChildComp.Name2 = NewName
Next i
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim swExportPDFData As SldWorks.ExportPdfData
Dim Ver As String
Dim Path As String
Dim status As Boolean
Dim errors As Long
Dim warnings As Long
Dim dFileName As String
Dim pFileName As String
Dim bOldSetting As Boolean
bOldSetting = swApp.GetUserPreferenceToggle(swExtRefUpdateCompNames)
swApp.SetUserPreferenceToggle swExtRefUpdateCompNames, False
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
Set swCustProp = swModel.Extension.CustomPropertyManager("")
pFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
pFileName = Left(pFileName, InStrRev(pFileName, ".") - 1)
'Path = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\"))
'pFileName = "c:\temp\" + pFileName + " " + Revision + "_" + Ver
status = swModelDocExt.SaveAs("c:\temp\" + pFileName + " " + Revision + "_" + Ver + ".sldasm", 0, 2, swExportPDFData, errors, warnings)
'Open assembly
Set swModel = swApp.OpenDoc6("c:\temp\" + pFileName + " " + Revision + "_" + Ver + ".sldasm", swDocumentTypes_e.swDocASSEMBLY, swOpenDocOptions_e.swOpenDocOptions_Silent, "", errors, warnings)
Set swConf = swModel.GetActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
'Debug.Print "File = " & swModel.GetPathName
'Traverse Components
TraverseComponent swRootComp, 1
status = swModel.Extension.SaveAs("c:\temp\" + pFileName + " " + Revision + "_" + Ver + ".step", 0, swSaveAsOptions_e.swSaveAsOptions_Silent, Nothing, errors, warnings)
'swApp.SetUserPreferenceToggle swExtRefUpdateCompNames, bOldSetting
swApp.CloseDoc pFileName + " " + Revision + "_" + Ver + ".sldasm"
status = swModel.ForceRebuild3(False)
swApp.SetUserPreferenceToggle swExtRefUpdateCompNames, True
