Should I design bolt or use bolt connector for bolt failure?
Question asked by Sadegh Fffff on Jan 26, 2019
Latest reply on Jan 27, 2019 by Sadegh Fffff
I want to perform a simulation on this assembly. There is a bolt in the specified area (and the pin is supposed to have threads, matching the bolt).
There will be bearing supports on bushes (pin will spin inside bearings).
Problem Conditions:
1. Dynamic process (teacher mentioned "explicit dynamics" which I don't know what exactly it is )
2. Considering Large displacement
3. 36NM pre-load torque on bolt
Things that I'm asked to answer:
1. bolt stresses
2. will bolt get to failure condition under specific forces and torques (and to find out where the failure exactly happen)
Now I want to know if I should design bolt (with exact threads) and also create threads on the pin hole, or I can just use bolt connector in simulation.
