I am trying to create a macro to modify some variables of a file card. I thought it would be quite easy but I am struggling with Setvar. This is basically the code:
Dim abc As String
Dim retval As Variant
Dim j As Boolean
Dim File As IEdmFile5
Dim Folder As IEdmFolder11
Dim RootFolder As IEdmFolder11
Dim VarMgr As IEdmVariableMgr7
Dim VarPos As IEdmPos5
Dim EnumVar As IEdmEnumeratorVariable10
Dim configs As EdmStrLst5
Dim pos5 As IEdmPos5
Dim config As String
Set File = Vault.GetFileFromPath(swApp.ActiveDoc.GetPathName, Folder)
Set RootFolder = Vault.RootFolder
Set EnumVar = File.GetEnumeratorVariable
Set configs = File.GetConfigurations()
Set VarMgr = Vault
Set VarPos = VarMgr.GetFirstVariablePosition
Do While Not VarPos.IsNull
Dim Var As IEdmVariable5
Set Var = VarMgr.GetNextVariable(VarPos)
Set pos5 = configs.GetHeadPosition()
Do While (Not pos5.IsNull)
' Gets the current configuration name
config = configs.GetNext(pos5)
If Var.Name = "Description" Then
Select Case config
Case "@"
EnumVar.SetVar Var.Name, config, "New Description", True
End Select
EnumVar.CloseFile (True)
Loop
Loop
And this is the error that appears on Setvar's line:
Run-time error '-2147220991 (80040201)'
The program used an object without initializing it properly first.
Any idea of what it is happening?
Thank you.
Rafa
