macro that checks if part/assembly is excluded from BOM
Question asked by Sean Leahy on Jan 24, 2019
Latest reply on Feb 5, 2019 by Sean Leahy
i have a macro that automatically creates a drawing for every part and assembly in a selected folder. i would like help to modify this so that it skips over any part or assembly that has the exclude from BOM checked. below is the macro script
Option Explicit
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const MAX_PATH As Long = 260
Dim swDrawing As DrawingDoc
Dim filename As String
Dim ext As String
Dim longerrors As Long, longwarnings As Long
Dim swApp               As SldWorks.SldWorks
Dim swSktManager        As SldWorks.SketchManager
Dim swModel             As SldWorks.ModelDoc2
Dim swModelDocExt       As SldWorks.ModelDocExtension
Dim swSheet             As SldWorks.Sheet
Dim sPath               As String
Dim Path                As String
Dim swFilename          As String
Dim nErrors             As Long
Dim nWarnings           As Long
Dim Response            As String
Dim DocName             As String
Dim bret                As Boolean
Dim swDocTypeLong       As Long
Dim vConfs              As Variant
Dim vPropNames          As Variant
Dim i                   As Integer
Dim j                   As Integer
Dim fso                 As New Scripting.FileSystemObject
Dim MYext               As String
Dim swCustPropMgr       As SldWorks.CustomPropertyManager
Function BrowseFolder(Optional Caption As String, _
    Optional InitialFolder As String) As String
Dim SH As Shell32.Shell
Dim F As Shell32.folder
Set SH = New Shell32.Shell
Set F = SH.BrowseForFolder(0&, Caption, BIF_RETURNONLYFSDIRS, InitialFolder)
If Not F Is Nothing Then
    BrowseFolder = F.Items.Item.Path
End Function
    Path = BrowseFolder()
    If Path = "" Then
    MsgBox "Please select the path and try again"
    End
    Else
    Path = Path & "\"
    BatchFolder Path, ".SLDPRT", ".SLDASM", True
    MsgBox "DONE"
Sub BatchFolder(folder As String, ext As String, ext2 As String, silent As Boolean)
    If Right(folder, 1) <> "\" Then folder = folder & "\"
    ChDir (folder)
    Response = Dir(folder)
    Do Until Response = ""
        swFilename = folder & Response
        Debug.Print swFilename
        MYext = Right(UCase$(Response), 7)
        If MYext = ext Or MYext = ext2 Then 'this is a file type we want, process it
            swDocTypeLong = Switch(MYext = ".SLDPRT", swDocPART, MYext = ".SLDDRW", swDocDRAWING, MYext = ".SLDASM", swDocASSEMBLY, True, -1)
            Set swModel = swApp.OpenDoc6(swFilename, swDocTypeLong, swOpenDocOptions_Silent, "", nErrors, nWarnings)
            Set swModelDocExt = swModel.Extension
            vConfs = swModel.GetConfigurationNames
            For i = 0 To UBound(vConfs)
                Debug.Print " Main: " & vConfs(i)
                If vConfs(i) <> "Custom" Then ClearCustPrps (vConfs(i))
            Next
            swModel.ShowNamedView2 "*Isometric", -1
            swModel.ViewZoomtofit2
            swModel.ForceRebuild3 False
            swModel.Save2 silent
            swApp.CloseAllDocuments (True)
        Response = Dir
    Loop
    Dim myFolder As folder
    Dim mySub As folder
    Set myFolder = fso.GetFolder(folder)
    For Each mySub In myFolder.SubFolders
        BatchFolder mySub.Path, ext, ext2, silent
    Next
Sub ClearCustPrps(conf As String)
Set fso = CreateObject("Scripting.FileSystemObject")
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then Exit Sub
filename = swModel.GetPathName
ext = UCase(Right(filename, 6))
If ext <> "SLDPRT" And ext <> "SLDASM" Then Exit Sub
Dim curfilename As String
curfilename = Left(filename, Len(filename) - 7) & ".SLDDRW"
If fso.FileExists(curfilename) Then
    If MsgBox(curfilename & " already exists. Overwrite?", vbYesNo + vbQuestion) = vbNo Then Exit Sub
Dim template As String
template = swApp.GetUserPreferenceStringValue(swDefaultTemplateDrawing)
Set swDrawing = swApp.NewDocument(template, 0, 0, 0)
If swDrawing Is Nothing Then
MsgBox "Failed to create drawing"
Exit Sub
If (ext = "SLDPRT") Then
    swApp.OpenDoc6 filename, swDocPART, swOpenDocOptions_ReadOnly, "", longerrors, longwarnings
Else: swApp.OpenDoc6 filename, swDocASSEMBLY, swOpenDocOptions_ReadOnly, "", longerrors, longwarnings
swDrawing.Create3rdAngleViews2 filename
Dim cursheet As Sheet
Dim sheetwidth As Double, sheetheight As Double
Set cursheet = swDrawing.GetCurrentSheet
cursheet.GetSize sheetwidth, sheetheight
Dim view As view
Dim vOutline As Variant, vPosition As Variant
Dim viewWidth As Double, viewHeight As Double
Set view = swDrawing.CreateDrawViewFromModelView3(filename, "*Isometric", sheetwidth, sheetheight, 0)
vOutline = view.GetOutline
vPosition = view.Position
viewWidth = vOutline(2) - vOutline(0)
viewHeight = vOutline(3) - vOutline(1)
vPosition(0) = vPosition(0) - viewWidth
vPosition(1) = vPosition(1) - viewHeight
view.Position = vPosition
Dim v As view
Set v = swDrawing.GetFirstView ' Sheet
Set v = v.GetNextView ' First view
swDrawing.ClearSelection2 True
While Not v Is Nothing
    If v.Name <> view.Name Then swDrawing.Extension.SelectByID2 v.Name, "DRAWINGVIEW", 0, 0, 0, True, -1, Nothing, 0
Wend
swDrawing.InsertModelAnnotations3 0, 327663, True, True, False, False
swDrawing.SaveAs2 curfilename, 0, False, False
