Not necessarily SolidWorks related.
When is the diameter symbol required in the tolerance for true position?
I'm still scratching my head trying to remember when or if I've ever not used a circular tolerance zone. Can't seem to remember any..
Steve C
Steve C
Keyways/slots wouldn't be circular.
Also, if you want to loosen the tolerance in one direction (say, along a slot axis) but keep the other direction "tight" (square to the slot axis), then you can specify different tolerances for each direction.
Kevin
ASME.org has the standard:
Y14.5 - 2018 Dimensioning and Tolerancing
They also have a handbook that elaborates more than the standard (but the standard is the standard):
Geometric Dimensioning and Tolerancing Handbook: Applications, Analysis & Measurement (GDT-HDBK - 2009)
https://www.asme.org/products/books/gdthdbk-geometric-dimensioning-tolerancing
I own both and recommend both.
Kevin
CORRECTION:
I have the 2009 standard, so I can't attest to the 2018 edition:
BTW, if you're attending World this year, Thomas Allsup has done several GD&T classes and knows his stuff. He might be willing to part ways with his presentation.
Steve C
I recommend Al and Scott Neumann for GD&T training. They also have a their textbooks for sale, at GD&T Technical Drawing & Engineering Drafting Courses | TCI GeoTol
Dwight
When you want the tolerance zone to be circular and not square.
