What are the options/methods and best practices for checking in another user's data when they are not available (vacation, no longer employed, etc)? Using PDM Professional 2016.
- Does it matter where the vault cache is located?
- Do you have to be an admin to check in their files?
- If not using Windows authentication/login does this effect?
Thanks in advance!
Hi Dan, even if Windows Auth is used, you can open the PDM Administration Tool on the users computer (Start, All Programs, SOLIDWORKS PDM, Administration), double click Settings underneath local settings, then on the Automatic Login tba, select the vault in question, and untick "use server default" - this will then allow you to log into the vault view on the user's machine as Admin (who is not a Windows user) , and then check the files in (preserving locallly saved changes). Once finished, you can log off the vault view as Admin, open the Administration tool again, go to Local settings, and turn on "use server default" so when the user logs in next, Windows Auth is active again for them.
If access to the users machine is not available, then you can log in as Admin from any other machine and do an Undo Checkout which discards any locally saved changes.
I hope this helps.
Kind regards
Prasad Bhonsule
