Macro for SW Custom Properties.
Question asked by Ben Froese on Jan 22, 2019
Latest reply on Jan 22, 2019 by Ben Froese
Hey Guys,
I have a macro that I cannot seem to get to function properly.
What I want is for the macro to choose values from the Configuration Specific menu in the Properties Manager but instead it is taking values from the Custom menu. How can I get the macro to choose the Config Specific menu?
Macro is pulling values from here
I want the macro to pull values from here.
this is the macro
Option Explicit
Dim swCustPrpMgr As SldWorks.CustomPropertyManager
Dim nFileName As String
Dim Value As String
Dim Qty As String
Dim FilePath As String
Dim MTRL As String
Dim Thickness As String
Dim vConfNameArr As Variant
Dim sConfigName As String
Dim i As Long
Dim bShowConfig As Boolean
Dim bRebuild As Boolean
Sub Main()
Set swModel = swApp.ActiveDoc
' Check the document is a sheet metal part
If swModel Is Nothing Then
MsgBox "Please open a Sheet Metal Part"
Exit Sub
If swModel.GetType <> swDocPART Then
Exit Sub
If swModel.GetBendState = swSMBendStateNone Then
Exit Sub
'Get Document Path
FilePath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\"))
'Get Document Name without extension
nFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
nFileName = Left(nFileName, InStrRev(nFileName, ".") - 1)
*** this is the section that needs to change
'Get Custom Property
Set swCustPrpMgr = swModel.Extension.CustomPropertyManager("")
swCustPrpMgr.Get3 "Thickness", False, "", Value
swCustPrpMgr.Get3 "Material", False, "", MTRL
thanks for your help.
