Hello everyone.
I can't seem to get hole wizard to create the holes I need.
The surface I wan't the holes is, has a bend radius of 206mm (inside) and the holes need to be aligned to the surface center.
I need a distance C/C (center to center) of 60mm from hole to hole.
How would I create the holes?
The part is made as a weldment structural member.
In this case, you should place two points in original sketch and use them later for holes
