I am curious if the two features in this assembly can be merged together into one feature...can it be done?
Bob
Bob
Thanks for the replies. I mainly use SolidWorks for sheet metal and haven't worked much with solids. I was given several non-native solid models that need to modified. This particular part needed to be just widened. So I figured that by cutting it in half and mirroring the half section then mating the two parts in an assembly would work. I was hoping that the two components could be merged into one solid but didn't know how to accomplish it. I can't join the two components because join is greyed out. What am I missing?
Bob,,, From the assembly menu select "New Part" your cursor will become a green check mark. Click anywhere on the work area then edit the new virtual part (right click from tree). Then the Join command will be active.
When you select "New Part" you may have to select a part template depending how your setting are.
You can also use the "Join" command in the assembly. Make new part, edit new part, then Insert>features>Join..
Then you end up with a new part and assembly file that looks like this. Assembly file shown
You can make the part virtual.
