Is it possible to make a weldment cutlist wich quickly shows if the profiles contains hole's and/or angles?
I would like to know if it's possible to make a cutlist with a column "hole" and a column "angle" wich will result "yes" if they are present in that profile,
Is it possible for solidworks to reconize if there is a cut-extrude present. and to answer this with Yes/No?
I am aware of the cutlist wich shows you the angles, but since this isn't enough information for the sawman,
I'd rather have a refecerence for him to know if he has to check the drawing for any special actions.
Does anyone know how to do this?
I have only come up with one approach for the holes and it is very manual.
The idea is to add a cut list custom property in the model called something like "Has Holes" and add a value of "Yes" or "No". This would be manually determined and entered by the engineer or CAD operator. Your cut list can then add a column referenced to this property.
All this does is transfers the workload / responsibility from the cut person to the designer. Not very elegant. It is arguable that the designer should be more familiar with which members have holes.
Daen
