I want to coincide these two blocks. But I could not see any fly out menu popups to enable the mate . What is reason for that?
Hi Maha,
Looking at your assembly files, it doesn't seem like those faces are planar (flat). But they do seem to fit together perfectly. Adding a coincident mate between these two corners should accomplish what you are trying to do.
After mating, you can run Interference Detection on the assembly and see that the parts are not intersecting.
Hi Maha,
