A dimension in my drawing needs an override applied. Other dimensions contain fractions win stacked format. The overridden dimension always has its fraction horizontal, not stacked like the others (which is not new, but I've ignored it in the past).
Is there an Option to make overridden dimensions display the same as ones without overrides?
Change the dimension you intend to override from fraction to decimal using the 'Other tab'. Then override the value (in decimal). Finally change it back to fractional using the 'Other' tab.
