I recently added a second monitor for using SW with both
displays. I unchecked the "Maximize window on open" option so the
files don't open across both screens. The window that opens now is
only slightly smaller than a "maximized" window and is not a useful
size spanning across both onf the monitors. I can resize the window
to smaller than a single monitor to work more efficiently but SW
does not save this size and always opens at near maximum.
Is there a way to have SW remeber the window size like othe applications?
There may be another option that will at least help get things under control. If you are using an nVidia graphics card, you can turn on "desktop management" and some of the tools there will add window controls to allow you to maximize a window to one monitor, even if the application spans more than one monitor. It's been a while since I did this, so I can't remember specifically how to do it. It's probably different in different versions of the driver anyway.
If you have ATI, I would think that something similar should be available.
