is there a one command way of removing the hatched area with the purple body? Like boolean objects in other software. The combine feature doesn't give a lot of options. The purple is piercing the grey rectangular piece - they are separate bodies. There is cut with surface but I have to offset all faces and by that time it is easier to create a sketch on the flat piece and blow a hole through it.
Thank,
you
Try the Intersect feature.
