Am I the only one who uses the mouse zoom reverse?
How can I change the mouse wheel direction in SW Visualize? (Like in SW View in System Options)
Thank you in advance,
Istvan
Istvan
Hi Istvan,
You can't change the mouse wheel zoom feature in Visualize yet. Hopefully they'll add that option in the future.
Being a decades long Photoshop user, I am so used to push in, pull out zooming with the wheel, just about every time I wheel zoom in Visualize I go the wrong direction.
We just have to live with it for now.
-Mark
After reading this post, I decided to create a utility that reverses the mouse wheel.
If you're interested, this utility can be found here: [Updated 09/19] Utility to [automatically] reverse mouse wheel direction (for programs w/o this option)
I hope it helps.
Kevin
Hello again,
Updated this utility and added a keyboard shortcut to toggle enable/disable by pressing Shift+Windows key+W.
Same post as above.
Kevin
Hello again,
Added the final version "Added "Reverse Mouse Wheel V2.exe" to [Updated 09/19] Utility to [automatically] reverse mouse wheel direction (for programs w/o this option)
With this V2 version, you select the program that you want to apply the mouse wheel reversal to.
And whenever this selected program is active (and V2 is running), the reversal kicks in.
Make any other program active and the reversal stops.
No interaction required on your part.
New files and how-to at the link.
Kevin
no you're not the only one:) me too
