I have a bunch of parts in an assembly that was imported from
Inventor. Picture a pneumatic cylinder, with several items stuck on
the end of the rod.
However, they come in without any mates. So, they are in the correct position, but if I attempt to pivot or extend the cylinder's rod, nothing else moves in the assembly. To recreate all the mates deleted by the importing process would take over an hour. So, I created an initial solution by adding all the parts on the rod end to an assembly.
However, I don't want to create this as an assembly, because it makes no sense to do so on the assembly instructions or the drawings I would create. What would be ideal is a way to group the parts together, much the same way as the "group" command works with 2d drawing elements in Microsoft Word.
Is there a way to do this?
Joe Dunfee
Joe Dunfee
There is a limitation, though. You can only apply a lock mate between two parts at a time. If you select several of parts, they are all unselected when you select the lock mate. This is a bit of a challenge for my assembly because there are a log of parts, and some of them are buried inside another.
Jay, regarding the "parts only" option of a BOM. I was aware of that, but that is an all or nothing option. You can't select which assemblies to show parts for and which not. So, it won't work for me.
It looks like I must mate each part individually, but at least I only need to do the lock mate, rather than 3 other types per part.
Thanks for all the replies.
[SEE THE CONTINUED DISCUSSION FOR SOME CORRECTIONS ON MY COMMENTS]
