Prepending Hole Callout Macro Help
Question asked by Adam Doerr on Jan 16, 2019
I'm trying to create a simple macro that works as follows:
Prereqs - A drawing file is open that already has a customized hole callout inserted (ex: Dimension Text = <hw-fstsze>mm DR. THRU, actual text on the drawing = Ø8.0mm DR. THRU)
1. Select the hole callout on the drawing
2. Run the macro
3. The callout now shows the hole quantity in parenthesis before the previous code (Dimension Text code = (<NUM_INST>) <hw-fstsze>mm DR. THRU, actual text shown on drawing = (3) Ø8.0mm DR. THRU)
Here's my current macro code (I started from a very old macro we use for a similar process though that macro does not use any Solidworks callout variables):
Dim swApp As Object
Dim Part As Object
Dim Gtol As Object
Dim FeatureData As Object
Dim Feature As Object
Dim ENTERDATA As String
Dim CURRENT As String
Dim Component As Object
Dim OC As Variant
Dim SELOBJ As Object
Set Part = swApp.ActiveDoc
Set SELMGR = Part.SelectionManager
OC = SELMGR.GetSelectedObjectCount
If OC = 0 Then
MsgBox "PLEASE SELECT AN OBJECT OR OBJECTS!"
For OI = 1 To OC Step 1
Set SELOBJ = SELMGR.GetSelectedObject3(OI)
CURRENT = SELOBJ.GetText(1)
ENTERDATA = "(<NUM_INST>) " & CURRENT
SELOBJ.SetText 1, ENTERDATA
Next
Part.WindowRedraw
_____________________________________________________________________
The problem is that it gets rid of the <hw-fstsze> callout variable and replaces it with the assessed text, thereby partially eliminating the parametric capability of the callout (ie; the callout becomes (<NUM_INST>) Ø8.0mm DR. THRU). Can anyone help me keep the callout fully parametric?
To help illustrate the callouts here are some screenshots:
Pre-macro
Desired post-macro
Current post-macro
