change component config in inactive assembly config
Question asked by jason van clark on Jan 16, 2019
Latest reply on Jan 17, 2019 by jason van clark
I am trying to write code that changes all instances of an assembly component when a user changes the configuration of one instance of the component.  I can do this fairly easily for the active assembly configuration, but I am having trouble doing it in inactive assembly configurations.  Does anyone have any advice?
Here's my VB.Net code.  It runs whenever a components configuration is changed.  It also (annoyingly) runs whenever a new component is added to the assembly.  Sorry there are no colors, not sure how to paste to keep them
    Private Function assemblydoc_CompChangeNotify(componentName As String, oldConfigurationName As String, newConfigurationName As String) As Integer
          'need to evaluate all components to make sure the same config of each is used in each config
        'remove the handler so I don't keep firing this function when I change component configs
        RemoveHandler iAssembly.ComponentConfigurationChangeNotify, AddressOf assemblydoc_CompChangeNotify
        'get names of all assembly configurations
        Dim configNames As Object = Document.GetConfigurationNames
        Dim activeConfig As Configuration = Document.GetActiveConfiguration
        Dim swAssy As AssemblyDoc = Document
        'get a list of the components in the active configuration
        Dim activeCompList As Object = swAssy.GetComponents(True)
        If activeCompList IsNot Nothing Then
            'get the name of the selected component minus the instance count for comparison sakes
            Dim selectedCompName As String = Left(componentName, componentName.LastIndexOf("-"))
            Dim myModelView As ModelView = CType(Document.ActiveView, ModelView)
            'turn off screen updating
            myModelView.EnableGraphicsUpdate = False
            'loop through the configs and change the configurations of the component
            For Each name As String In configNames
                'change the active assembly configuration
                Document.ShowConfiguration2(name)
                'loop through the component list, find the components and change the config
                For Each comp As Component2 In activeCompList
                    Dim compName As String = path.GetFileNameWithoutExtension(comp.GetPathName)
                    If compName = selectedCompName AndAlso comp.Name2 <> componentName Then
                        comp.ReferencedConfiguration = newConfigurationName
                Next
            Next
            myModelView.EnableGraphicsUpdate = True
        AddHandler iAssembly.ComponentConfigurationChangeNotify, AddressOf assemblydoc_CompChangeNotify
    End Function
