update in SubAssembly when Transform a part
Question asked by Lenny Yang on Jan 15, 2019
Latest reply on Jan 17, 2019 by Artem Taturevych
Hi every one ,
I have some question about transform a part in subassambly.Iwant to update the location when I trandform a partdoc in subassambly for make a animation.
can you help me ?
thank you very much .
here is the code======================================
'Just Open the "TopAssem.SLDASM" and run this macro.
'you can see "Part1-1" have been update to correct location,but "Part1-2" is incorrect.
Dim swApp As Object
Set swModel = swApp.ActiveDoc
Dim swComp1 As SldWorks.Component2
Dim swComp2 As SldWorks.Component2
'The "Part1-1" is Fix in SubAssem,it can update location when  "MoveComp(swApp, 0.3, swComp1)" finished immediately.
'PS:If a part or assembly if belong the "TopAssem" Directly,it can update location immediately whether it is floating or not.
Set swComp1 = GetCompByName(swModel, "Part1-1")
Call MoveComp(swApp, 0.3, swComp1)
'The "Part1-2" is Float in SubAssem(Assem1) of TopAssem.and when the"MoveComp(swApp, 0.2, swComp2)" finished it can not Update location.
'In order to display the correct location I have to rebuild the AssemblyDoc.
'PS:I don't want to Rebuild the model,because I want to make a Animation by this macro,It may move the part several times a second,if I rebuild the model the Animation will be stuck.
Set swComp2 = GetCompByName(swModel, "Part1-2")
Call MoveComp(swApp, 0.2, swComp2)
Function GetCompByName(swModel As SldWorks.ModelDoc2, CompName As String) As SldWorks.Component2
    Set swAssy = swModel
    Set swComp = swAssy.GetComponentByName(CompName)
    Set GetCompByName = swComp
End Function
Sub MoveComp(swApp As SldWorks.SldWorks, MoveDistance As Double, swComp As SldWorks.Component2)
    Dim swMathUtil As SldWorks.MathUtility
    Dim swXform As SldWorks.MathTransform
    Dim i As Long
    Dim bRet As Boolean
    Set swMathUtil = swApp.GetMathUtility
    Dim MathVxform As SldWorks.IMathTransform
    Dim Xform(15) As Double
    Dim vXform As Variant
    Xform(0) = 1#
    Xform(1) = 0#
    Xform(2) = 0#
    Xform(3) = 0#
    Xform(4) = 1#
    Xform(5) = 0#
    Xform(6) = 0#
    Xform(7) = 0#
    Xform(8) = 1#
    Xform(9) = MoveDistance
    Xform(10) = 0#
    Xform(11) = 0#
    Xform(12) = 1#
    Xform(13) = 0#
    Xform(14) = 0#
    Xform(15) = 0#
    vXform = Xform
    Set swXform = swMathUtil.CreateTransform(vXform)
    swComp.Transform2 = swXform
    swModel.GraphicsRedraw2
