Personally, I've found that if you make the parts for Tubing or Piping (only round ducting) they are more versitile and easier to work with. I also have found that it's easier to do a save-as of existing route parts (from SW library) and modify as desired.
Unfortunately, there is a myriad of problems with SW routing, and at times you have to find a work-around in order to avoid errors and crashes.
Note, HVAC falls under "User-Defined Routes"
See https://www.youtube.com/watch?v=VPwwbUz7p34
Once you've made your custom part / development, add in C-Points as described in SolidWorks Help, (http://help.solidworks.com/2018/English/SolidWorks/sldworks/HelpViewerDS.aspx?version=2018&prod=SolidWorks&lang=English&path=sldworks%2fc_introduction_toplevel_topic.htm&verRedirect=1)
Do NOT use revolves to make routing parts.
Let us know how it turns out!
Good luck!
