Hello!
Why I cant have the same component tag in different locations?
Example:
If I have main function for example: "Main enclosure"
And I have location: "+24V devices"
And component main PLC: "A0"
It would generate formula for example: =L1+001-A0
Now I have second enclosure and I cannot use A0 anymore but it is totaly different location
Formula would be: =L2+001-A0. It is same for solidworks as =L1+001-A0 but its different function.
Why solidworks only reconize component tag not a full formula for the component?
Case is that I downt want to have button S100 in my project. If I have to add a button witch should be indexed S5 then I need to renumber all the buttons witch should generate probably so many errors. Its would be better if every location numbering starts with S1 again.
You should be able to handle the same mark within a project as long as you adjust this setting to allow marks unique by location:
