I see in the cable properties you can input voltage drop (V/A/km). Then after you have a cable in the schematic you can input the applied voltage and full load current. The thing I can't find is the output of this information. I would like a report or a customize the wire label to tell me the voltage drop. I checked the help file but it only has 1 result for "voltage drop". Just seeing if anyone was able to use this feature successfully.
Zac
in the design rules check, there is a “voltage drop in cables", you can see the voltage drop values , but I don't know how to use them
