Please I need help relate a gasket that didn’t snap on the right position. I created this custom gasket and I applied the c points and route point in similar way like a standard gasket from design library after that I introduce this custom gasket in Design Library. Unfortunately, when I try to use in a simple route this custom gasket didn’t snap on the right position appear a gap, I tried many times and didn’t snap where is the right position on the slip flange. Please see the attach files parts asm and pdf, thank you, I very appreciate a practical stabile answer solution, thank you so much I appreciate.
Best,
Sorin,
Sorin,
In the file you send there are no CP or RP point defined.
and you put a gasket in the wrong ASM
Unless you intend to use the gasket as a starting point it can't be the first item in the sub-ASM
Further more you're using GASKET FLG 3_INCH in there but you send us GASKET FLG 3
In short, there's so much wrong on so many levels.
Try again.
