DSDamien Symons10/01/2019
Im looking for some advice on if it is possible to check the units of parts withing an Assembly, from the Assembly level. (?Macro or other feature?)
We regularly change between imperial and metric depending on fabrication location and regularly have the problem that a component is copied from an imperial to a metric design project but weight units of the component are not changed, and so on the metric assembly the BOM weight shows as the pounds value.
My question is if there is a way to identify this variable of the parts but at the assembly level to not then have to manually check each part file manually?
Appreciate your comments.
-Damien.
