Cannot get this macro to work to save my dxf at a desired location
Question asked by Baljinder Shahi on Jan 10, 2019
Latest reply on Jan 10, 2019 by Cad Admin
Can somebody Please help rectify problem in this code i am very bad at VBA
Option Explicit
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const MAX_PATH As Long = 260
Dim swSelMgr As SelectionMgr
Dim swSelData As SelectData
Dim swFace As Face2
Dim swSurf As Surface
Dim sModelName As String
Dim sPathName As String
Dim varAlignment As Variant
Dim dataAlignment(11) As Double
Dim varViews As Variant
Dim dataViews(1) As String
Dim options As Long
Dim exportType As String
Dim numSel As Integer
Dim selType As Integer
Dim result As Boolean
Dim i As Integer
Function BrowseFolder(Optional Caption As String, _
    Optional InitialFolder As String) As String
Dim SH As Shell32.Shell
Dim F As Shell32.Folder
Set SH = New Shell32.Shell
Set F = SH.BrowseForFolder(0&, Caption, BIF_RETURNONLYFSDIRS, InitialFolder)
If Not F Is Nothing Then
    BrowseFolder = F.Items.Item.Path
End Function
Sub exportDXF()
'*** Change to dxf or dwg depending on which file type you want to export
exportType = "dxf" '"dwg"
'Get Solidworks and and active model
Set swModel = swApp.ActiveDoc
'Make sure a model is open
If swModel Is Nothing Then
    MsgBox ("Error! No model open")
    Exit Sub
'Make sure model is part
If swModel.GetType = swDocPART Then
    Set swPart = swModel
    Else
    MsgBox ("Error! Must use part document")
    Exit Sub
'Set the selection manager and get the number of selections
numSel = swSelMgr.GetSelectedObjectCount2(-1)
'Make sure at least one face is selected
If numSel < 1 Then
    MsgBox ("Error! Please select at least one planar face to export")
    Exit Sub
'Check all selections are planar faces
For i = 1 To numSel
    Set swFace = swSelMgr.GetSelectedObject6(i, -1)
    Set swSurf = swFace.GetSurface
    'Exit for nonplanar surface
    If swSurf.IsPlane = False Then
    MsgBox ("Error! Non planar surface selected")
    Exit Sub
Next i
'Get the pathname
sModelName = swModel.GetPathName
sPathName = BrowseFolder(Caption:="Select A Folder/Path")
    If sPathName = "" Then
    MsgBox "Please select the path and try again"
    End
    Else
    sPathName = sPathName & "\"
    Exit Sub
'change the file extension to dxf (or dwg)
sPathName = Left(sPathName, Len(sPathName) - 6)
sPathName = sPathName + exportType
'Define the alignment types
'I had to set them all to 0 in order to output in same orientation as 3D model
dataAlignment(0) = 0#
dataAlignment(1) = 0#
dataAlignment(2) = 0#
dataAlignment(3) = 0#
dataAlignment(4) = 0#
dataAlignment(5) = 0#
dataAlignment(6) = 0#
dataAlignment(7) = 0#
dataAlignment(8) = 0#
dataAlignment(9) = 0#
dataAlignment(10) = 0#
dataAlignment(11) = 0#
varAlignment = dataAlignment
'Export the selected face(s) to a DXF/DWG
result = swPart.ExportToDWG2(sPathName, sModelName, swExportToDWG_ExportSelectedFacesOrLoops, True, varAlignment, False, False, options, Nothing)
'Show error message if failed to save
If result = False Then
    MsgBox ("Error! Failed to export. Check selections and try again.")
    Exit Sub
