Rob Edwards
Delete Sketch Entities Smaller Than...  Macro
Discussion created by Rob Edwards on Jan 9, 2019
Latest reply on Jan 9, 2019 by Jerome De San Nicolás
It ain't pretty but gets the job done
' SOLIDWORKS 2016
' This macro will remove sketch entities smaller than a specified length (mm)
' Run the macro whilst editing a sketch OR
' You can select multiple sketches and it will ask for a dimension for each one
' By the way if you remove all the sketch entities SW will delete the sketch
' Warning - I'm a joiner not a programmer, so use at your own risk!
' https://forum.solidworks.com/people/1-2SZI4TC
Option Explicit
Dim swFeature As SldWorks.Feature
Dim bs As Boolean
    Set swModel = swApp.ActiveDoc
    If Not swModel Is Nothing Then
        If Not swModel.SketchManager.ActiveSketch Is Nothing Then
            Call ProcessActiveSketch
        Else 'check selections
            With swSelMgr
                Dim sketchFeatureCollection As New Collection
                Dim i As Integer
                For i = 1 To .GetSelectedObjectCount2(Mark:=-1)
                    If .GetSelectedObjectType3(index:=i, Mark:=-1) = swSelectType_e.swSelSKETCHES Then
                        Set swFeature = .GetSelectedObject6(index:=i, Mark:=-1)
                        Call sketchFeatureCollection.Add(Item:=swFeature)
                Next
                Select Case True
                       Case sketchFeatureCollection Is Nothing, sketchFeatureCollection.Count = 0
                                Call swApp.SendMsgToUser2("No Active Sketch or Sketches Selected", swMbStop, swMbOk)
                                Exit Sub
                End Select
            End With 'swSelMgr
            For i = 1 To sketchFeatureCollection.Count
                Set swFeature = sketchFeatureCollection(i)
                bs = swFeature.Select2(Append:=False, Mark:=-1)
                swModel.EditSketch
            Next i
Private Sub ProcessActiveSketch()
    Dim swSketchSegment As SldWorks.SketchSegment
    Dim smallSegmentCount As Integer
    Dim vSegments As Variant
    Dim minLength As Double
    Dim exitLoop As Boolean
    exitLoop = False
    Do Until exitLoop
        With swModel.SketchManager.ActiveSketch
            vSegments = .GetSketchSegments
            swModel.ClearSelection2 True
            Dim userInput As Variant
            userInput = InputBox("Minimum Length(mm)", .Name)
            If userInput = "" Then
                exitLoop = True
            Else
                minLength = CDbl(userInput) / 1000
                smallSegmentCount = 0
                Dim j As Integer
                For j = LBound(vSegments) To UBound(vSegments)
                    Set swSketchSegment = vSegments(j)
                    If swSketchSegment.GetLength < minLength Then
                        smallSegmentCount = smallSegmentCount + 1
                        bs = swSketchSegment.Select4(True, Nothing)
                Next j
                Select Case swApp.SendMsgToUser2(smallSegmentCount & " entit" & _
                                                IIf(smallSegmentCount = 1, "y", "ies") & " less than " & minLength * 1000 & "mm selected in " & .Name & vbCr _
                                                & "Delete? - Yes" & vbCr & "Change threshold - No" _
                                                , swMbQuestion, swMbYesNoCancel)
                       Case swMbHitYes: swModel.EditDelete: exitLoop = True
                       Case swMbHitCancel: exitLoop = True
                      'Case swMbHitNo: exitLoop = False
                End Select
        End With 'ActiveSketch
    Loop
    swModel.SketchManager.InsertSketch True
