* I'm currently re-organising all my macros and I found a few I'd forgotten about. So I'll try and tidy them up a bit and post them.
' SOLIDWORKS ' This macro will flip (toggle) 'Marked for Drawing' on all your dimensions. ' Works in a part file or an assembly but doesn't go down into your components ' Warning - I'm a joiner not a programmer, so use at your own risk! ' https://forum.solidworks.com/people/1-2SZI4TC Option Explicit Dim swApp As SldWorks.SldWorks Dim swModel As SldWorks.ModelDoc2 Dim swSelMgr As SldWorks.SelectionMgr Dim swFeature As SldWorks.Feature Dim swDisplayDimension As SldWorks.DisplayDimension Dim swDimension As SldWorks.Dimension Dim colFeaturesWithDims As Collection Dim colDispDims As Collection Sub main() Set swApp = Application.SldWorks Set swModel = swApp.ActiveDoc Set colFeaturesWithDims = New Collection Set swFeature = swModel.FirstFeature Do While Not swFeature Is Nothing If HasDisplayDimensions(swFeature) Then On Error Resume Next 'we don't care if already in the collection Call colFeaturesWithDims.Add(Item:=swFeature, key:=swFeature.Name) On Error GoTo 0 End If Set swFeature = swFeature.GetNextFeature Loop Dim i As Integer For i = 1 To colFeaturesWithDims.Count Debug.Print colFeaturesWithDims(i).Name Next Set colDispDims = New Collection For i = 1 To colFeaturesWithDims.Count Set swFeature = colFeaturesWithDims(i) Set swDisplayDimension = swFeature.GetFirstDisplayDimension Do While Not swDisplayDimension Is Nothing On Error Resume Next 'we don't care if already in the collection Call colDispDims.Add(Item:=swDisplayDimension, key:=swDisplayDimension.GetDimension.FullName) On Error GoTo 0 Set swDisplayDimension = swFeature.GetNextDisplayDimension(swDisplayDimension) Loop Next For i = 1 To colDispDims.Count Set swDisplayDimension = colDispDims(i) With swDisplayDimension Debug.Print .GetNameForSelection, .MarkedForDrawing .MarkedForDrawing = IIf(.MarkedForDrawing, False, True) End With Next Call swApp.SendMsgToUser2(colDispDims.Count & " dimension" & IIf(colDispDims.Count = 1, "", "s") & " flipped", swMbInformation, swMbOk) End Sub Private Function HasDisplayDimensions(swFeature As SldWorks.Feature) As Boolean HasDisplayDimensions = Not swFeature.GetFirstDisplayDimension Is Nothing End Function
Thanks for sharing.
I have collected some macros through the years and like to reference other's methods and solutions when I need to write my own.
