4 Replies Latest reply on Jan 11, 2019 10:19 AM by Sorin Albu
    Routing Fitting Inside type Connection
    Sorin Albu
      Please see the pdf
      in attach file, please I need help relate how to use route settings to create
      the next connection between slip on weld flange and a tee, the tee must snap
      inside of the slip on flange ¼”, the same idea for a pipe connect to slip on
      flange but the pipe or slip on flange must connect inside too ¼”, and third the
      elbow connect to the slip on flange but the elbow must snap inside of the slip
      on flange, these are real technically routing connection , I don’t know how to
      create these connections how to control where I must set and what in the same
      time in stabile way using routing in SW2016, thank you so much I appreciate.
      Sorin,
