hi. I have a problem which shows up when I split an assembly and save the sections. When I open up a single section later there is the section showing I want but also a second part. The second part is something I made years back and now is turning up each time I try to save or open I split body file. I just don’t know how to find the root of the problem. I have deleted all the saved files of the bad part. So it must be in the solidworks way of saving things that I don’t know about. The bad part is an assembly I made years back and it sort of takes over from the split part I do want to save or open. Is there a way to find and remove this unwanted assembly. Thanks
Is it possible you saved a drawing template with this Part in it?
