We're in the midst of migrating from our old PDM system to PDM Pro. IT is managing set-up and migration, and I'm trying to figure out what I'll have to deal with.
In our old PDM, we'd search for a part number. A list of matches would come up and we'd click on the one we wanted. This was a web-based system, so it would open a webpage that was essentially the data card for the part. On that webpage, there would be info about the part and a link to the drawing. We could either open the pdf, save the pdf, or click through to the drawing data card.
From what I've seen of PDM Pro, there are no links. If I had only the part number, I'd have to search for that part, get the drawing number from the data card, and then perform a second search for the drawing. Is this true? Are there any options so that we don't have to run a second search?
PDM will display the parent-child relationship between model-files and drawings. By using Contains and Where Used tabs, you can easily find the correct file. This demands that the import and initial check-in makes sure that file relationships are maintained.
Selecting a part, and activating "Where Used" tab, i get which assembly(-ies) and drawings(s) it's referenced in:
You will have the same options from PDM Search result.
-M
