Disappearing tolerances
Question asked by Greg Welch on Jan 3, 2019
Latest reply on Jan 3, 2019 by Greg Welch
I'm using SW 2018 SP 4.0.  We switched to this version at work a month or two ago.  Since then, I've noticed something haven't seen before.  I made a hole in a part using the hole wizard, and then, on a drawing, called out the hole as a hole, and added a tolerance.  I then went back into the part file and opened up the hole, changed nothing, and closed it.  When I went back to the drawing, the tolerance had disappeared.  I did this multiple times on multiple computers all using the same SW version and got the same results.  If I create the same hole as a cutout, there's no problem.  If I call out the hole diameter with a standard smart dimension, there's no problem.  Does anyone know what's going on?
