Divide spline in equal parts (in x-axis not along the spline)
Question asked by Jure Košir on Jan 3, 2019
Latest reply on Jan 4, 2019 by Jure Košir
I am complete newbie when it comes to macros. Anyways, my goal is to split spline into number of points. I found one macro that does this very well, but the problem for me is that points that split the spline are "equally distanced" in terms of distance along the spline. As a result I get points, which are not equally distanced in terms of x coordinate (along x-axis) which is what I want...
I have an idea to split x-axis into equally distanced points and then project them on the spline to get points which have the same "step" in x coordinate. But I just simply have no knowledge to execute this I don't even know if this is a good idea. Any help would be very helpful...
I attached image below for better understanding. Orange arrow is along the spline and is equally distanced but x1 does not equal to x2, which is my goal..
MACRO:
Option Explicit
Dim vFeatArr As Variant
Dim swFeatMgr As SldWorks.FeatureManager
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swSpline As SldWorks.SketchSpline
Dim vFeat As Variant
Dim swFeat As SldWorks.Feature
Dim swRefPt As SldWorks.RefPoint
Dim swRefPtData As SldWorks.RefPointFeatureData
Dim swMathPt As SldWorks.MathPoint
Dim swSkPt As SketchPoint
Dim swMgr As SketchManager
Dim nStatus As Long
Dim bRet As Boolean
Dim boolstatus As Boolean
Dim i As Long
Set swModel = swApp.ActiveDoc
Set swFeatMgr = swModel.FeatureManager
Set swModelDocExt = swModel.Extension
If Not swSelMgr.GetSelectedObjectType3(1, -1) = swSelEXTSKETCHSEGS Then
MsgBox "select spline"
Exit Sub
Dim Spline As Object
Set Spline = swSelMgr.GetSelectedObject6(1, -1)
vFeatArr = swFeatMgr.InsertReferencePoint(swRefPointAlongCurve, swRefPointAlongCurveEvenlyDistributed, 0#, 300)
Set swMgr = swModel.SketchManager
swModel.ClearSelection2 True
swModel.Insert3DSketch2 False
swMgr.AddToDB = True
For Each vFeat In vFeatArr
Set swFeat = vFeat
Set swRefPt = swFeat.GetSpecificFeature2
Set swRefPtData = swFeat.GetDefinition
Set swMathPt = swRefPt.GetRefPoint
Set swSkPt = swMgr.CreatePoint(swMathPt.ArrayData(0), swMathPt.ArrayData(1), swMathPt.ArrayData(2))
Next
swMgr.AddToDB = False
swModel.Insert3DSketch2 True
